Tried setting as per manual but don't see speed dial for set up. Does anyone know how to set up speed dial...Mahalo from Hawaii
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To
call the number from your speed dial list, click on the "Phone dial"
icon, and hold the number down. For example, is the number 2 is home,
hold 2 down until you see it dial and there you have it.
Hopes this helps
You can find this at Call cent (at the bottom of the display, the second icon)/General call settings
SOURCE: Need wap settings for unlocked cect i9
Go to Main menu> Services>Data Account>GPRS
Select a profile and select "Edit profile"
Enter the following settings
APN: wap.cingular
user: [email protected]
password: Cingular1
Go to Main menu>Services>WAP>Settings>Edit profile
Select a profile and select "edit profile"
Enter in the following settings
Homepage: www.google.com
Data account: GPRS>Cingular
Connection type: HTTP
password: Cingular1
Then to browse, Go to main menu>Services>wap>homepage
You may get an error "Unsupported scripts in content" Just click ok.
If you have more problems let me know, we may have to tweak some things if you don't have a data package.
SOURCE: cect i9 passwords
all the phones have a default password from the company.for e.g nokia has the default password as 12345. you can find the code by referring to your instruction manual.thanks for using fixya!. please dont forget to rate my solution.
SOURCE: orange settings
At&t WAP Setup
***First Step***
1.Main menu --> Select Services
2.Select Data Account --> Select GPRS
3.Select the first entry
4.Edit the account name to whatever you would like
5.Edit APN to wap.cingular (lowercase)
6.Edit Username to [email protected] (UPPERCASE)
7.Edit Password to CINGULAR1 (UPPERCASE)
8.Edit Auth Type. to Secure
9. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
2.Select the first entry --> Edit Profile
3.Edit the name to whatever you would like
4.Edit Homepage to http://device.home
5.Edit Data Account to the Name you established in the First Step
6.Edit Connection type to HTTP
7.The IP address is 066.209.011.032 and the port number is 8080
8.Edit Username to [email protected]
9.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
