Working inside rotate the bowl
SOURCE: bread hook use
Use it to the side. This will pull the dry ingredients off the bowl. If the dough is coming out lumpy, make sure you follow the recipe exactly. Putting dry into wet will give different results than putting wet into dry. If this doesn't end the lumps, try a different type of flour.
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
SOURCE: dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
SOURCE: how do I adjust the depth of the dough hook.
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
If you are seeing an abundance of dry ingredients being left at the bottom of the bowl, I would suggest looking into this adjustment.
SOURCE: KitchenAid Parts
Given the age of a 3-C stand mixer, finding additional parts for it will be exceedingly difficult. The best recommendation is through E-Bay or antiques stores - a specialty dealer. Kitchenaid parts distributors will no longer have anything in inventory for the 3-C mixer.
