Treadmill Maintenance How To Lubricate Treadmill Belt LED Blink Patterns on the Control Board Treadmill
Follow this steps carefully, in order to fix it.
If the problem persist, time to REPLACE the Controller board motor., by new one or Rebuilt.
Blessing.
[email protected]
cell+whatsAPP:+50588611441
SOURCE: Proform Treadmill doesn't run constant speed.
You have a friction problem between your belt and deck. A treadmill of this age either came with a waxed deck, or requires periodic silicone lubricant spray on the deck. You can check your owners manual to see which type of surface your machine has. Typical belt life on a consumer grade treadmill is about 2 to 3 years. If you purchase a new belt from the manufacturer it will come pre-lubricated.
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
SOURCE: e1 error on york treadmill
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
SOURCE: E1 not ERR1 error appears on the display of
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
