Did you replaced any drum if yes please recheck or re Assemble it again there is some hi voltage leak issue
An error signal is detected for 0.2 seconds when charging the drum or development.
SOURCE: I have a Ricoh 1018D photocopier. However when i
try cleaning the optics and the laser glass
SOURCE: Ricoh FT2260 Copier
There are basically two types of error codes:
These type of errors are often caused by the following conditions:
The VirtualReScan error codes displayed below are accompanied by descriptions and troubleshooting suggestions.
Let me know if u got help?
SOURCE: Error 52 on ricoh FT3213.
error code 52 on ricoh ft3213, that's mean heating element burn out , such as heater lamp, thermister , thermo fuse.
SOURCE: i have a ricoh aficio
Waste toner bottle is to the left of tray one. all you will need to do is remove the tray one complertrely and open the left cover nexdt to the tray. the waste toner bottle is in there and you will have to pull it it gently.
good luck
