A CD is in the CD player. When I hit the Eject button the CD will not eject. IT still plays but will not eject.
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
SOURCE: CD Player does not eject CD
Just took one apart tonight. Same problem, put in cd-played fine-push eject then click click click.
2004 nissan sentra 140 watt single cd player/radio.
This dash comes apart by pulling the top of dash (with the tray) straight out the clips should release. the bottom part had to be pried a little, then remove four screws and slide out the radio still attached to the mount and dash etc. One screw holds on the top of the stereo. After removing the screw you must pry the top off. Now it gets a little tricky, you must remove the cd player portion, however there are 5 tiny springs holding it down to some pads. The two springs in the rear are under a piece of the stereos frame held on by two screws, I had to use various sizes of tweezers to get the springs off. Lift the player out of the radio about an inch, you will see one 1/2" ribbon in a connector, the top of the connector slides out along the ribbon to release. The other ribbon about the same size plugs into a small daughter board in the radio, it just pulls out and pushes in (you can feel it is reinforced). once out turn it over and you will see what would be considered a gearbox, (small white gears in a see through case) one of the corners of this case has a screw through it. This corner has broken away from the board letting the gears come apart when trying to eject (this is the clicking). I took a soldering iron and melted the plastic back together and put a small amount of 5-min epoxy on for good measure. When putting back into case you can hook up the ribbon cables before all the spring grief and test it out. Mine worked perfectly again. Be care full when putting back together, there are a lot of little micro switches that must be in the correct position) Example, if the cd is ejected the white arm on the right side must be in the correct position. the read head (laser) must be away from the center of the cd. I believe it was easier to put together with it in the cd-in position (without a cd in it) so the laser must be toward the center of the cd. Don't force the laser, use the worm gear to move it in or out. I couldn't put one of the springs back on but it still works fine Good luck, it's not as hard as it sounds
SOURCE: 2005 dodge ram cd player won't eject cd
the dealer told me not to use burned cds to long in the cd player. the cds are a little thiker then a regular cd. i had to not use the cd player for a couple of days. once the cd cooled down it cam back out and i havent had a problem since. Solution dont let burned cds get to hot
SOURCE: 2004 FORD F-150 CD EJECT ERR
I've had this happen once before..CDR's are a little bigger than regular cd's.Sometimes they wont let go at all..You either can undo the battery and then reconnect then it usually automatically ejects or you'll have to manually do it or you can pull the fuse and then put it back in and the same proceedure..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: 2002 Honda CRV factory radio - CD Plays but will not eject
mustangs do the same thing, on those if you swipe a credit card UNDER the cd while its ejecting it will come out, hope that helps.....
