SOURCE: how to solve runtime error in visual c++ and abnormal programme termination in Internet explorer 7
Run System File Checker (SFC) to correct any problems with system files, do a full scan.
Click Start/ Run / then type SFC and press ENTER, to launch the SFC dialog box. Also try removing any toolbars you might have in IE.
SOURCE: I nees to setup Quintum
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
SOURCE: quattro pro x3 abnormal program termination
1. Click Start, Programs, Accessories and Run.
2. In the open window, type: regedit and click OK.
3. Choose the following path
HKEY_CURRENT_USERS\Software\Corel\User\Assistant\13\Recent Work\Quattro
Pro\
4. Right click on the Quattro Pro folder, select delete.
5. Say yes when prompted to delete the key.
6. Close the Registry Editor
7. Launch Quattro Pro
This key will be re-created when you reopen Quattro Pro. I ran into this problem when when I tried to open a QP SS on my hard drive after previously opening one from my thumb drive. Now I copy to my hard drive first.
SOURCE: Microsoft Visual C++ Runtime error: abnormal termination
Download and install visual C++ here: Click Here
Then restart the computer
SOURCE: Tracert command always return Request timed out.
On your home pc you need to check you firewall or you anti virus settings disable both of them if you have both activated thne reboot your home pc and give it a go. its is normaly spy ware or security software that causes a tracert to time out.
