SOURCE: homelite yard blower won't start
1st how old is the gas and 2nd how long did it sit for since you last used it? If there was any old fuel left in before now (more than 14 days) than it is possible your carb needs cleaning. If it's less than 14 days then you might want to check the compression. IF you have good compression, then you might want to take it to a service center to have it diagnosed.
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
