The pilot light went out in the dryer but I have never worked on them how do I relight the pilot. It is an older machine
My friend it’s a dryer and never had a pilot light in the beginning you should have a igniter the glows then releases the gas that’s working properly if you never work on gas you should have somebody with experience look at it before you blow yourself up
There is normally a button you have to hold in until the thermocouple takes over- about 30 seconds after you light it.
THe "button"may be in the form of a KNOB with an indicator
SOURCE: Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
SOURCE: piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
SOURCE: Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
SOURCE: Pilot light does not stay on.
Be sure to keep the button pushed for 45 seconds AFTER lighting the pilot. If the pilot continues to go out, the problem is most likely the thermocouple. A replacement thermocouple can be purchased at the local hardware store for under $20.00.
