SOURCE: hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
SOURCE: How do I replace the light switch in a hampton bay
Hi ,,, replacement switches for ceiling fan lights can be found at most appliance or building supply stores. Try Home Depot, Ace, Lowes. Make sure that you get the correct switch. With a single lamp you only need an on/off switch.
SOURCE: 52 inch ceiling fan hampton bay--Humming.....
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at FixYa.com
SOURCE: Hampton Bay model AC-436 Ceiling Fan: remote fan
Did you ever find a solution? I'm having the same problem.
