SOURCE: I have a commercial cardiozone
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Good luck, sincerely.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
A "P Err" readout means there is an overload in the pump/master valve circuit. A readout of "1 Err" means there is an overload in station No. 1, while "2 Err" means an overload in station No. 2 and so on, depending on the number of total stations being operated by the controller.
An overload occurs when the wiring circuit is requiring more than .56 amps of current. This overload will typically occur when the field wiring or valve solenoid is shorted, or if the field wiring is a smaller gauge than required for the application and/or distance.
