SOURCE: Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
SOURCE: how to replace motor and circuit board in my peg
the motor is easy, just pull off the plastic hubcap with a flat head screwdriver, then remove the nut and bolt with a 13mm wrench, then pull off the wheel and gearbox and disconnect the wires from the motor then its just two screws that hold the motor on, for the circuit board it depends on wether you got the new style with the poly switches on the board or if they are seperate
Hi
There can be a number of reasons why it stopped working. When you have already changed the battery, then it must be something wrong with the inner mechanism. Try cleaning the circuit board.Take the razor apart (you need very small Phillips screwdrivers). Clean the circuit board with small amount of alcohol and q-tips, being careful not to catch any cotton on the components of the board. At this point you can at least confirm that the motor is not burnt out and the batteries are charged by placing a flathead screwdriver between the positive terminal of the battery and the motor. It should come on if the motor and batteries are okay. Press reset button at then see if it comes on using the on/off button. You can do this step with the razor disassembled or assembled.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
