Garbage Disposals Logo
J.J. Enser Posted on Oct 08, 2017
My garbage disposer stopped working - I can hear the engine hum when I flip the switch, but no part seems to be moving. Wondering if this can be fixed or if it's dead and needs to be replaced. Thx!!
Pressing the Reset button, or even unplugging it from power source doesn't help. Model: KitchenAid SuperBA KCDS075T
Dean Tong
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 22, 2017
Dean Tong
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9928
Points
Sometimes the disposal rotor is jammed by a piece of chicken bone for example. You can use the supplied hex key to stick into a hole at the bottom and jiggle the rotor free.
5 Related Answers
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 20, 2009
SOURCE: Garbage disposal won't turn on
Three points to ck. !) make sure disposer is plugged in under ther the sink. 2) Make sure the circuit breaker at the breaker panel has not tripped. 3) Make sure disposal is off and make sure it is not jammed, 3) Press reset breaker located on bottom of unit (red button.) Then try wall switch again.
Anonymous
  • 377 Answers
  • Posted on Sep 11, 2010
SOURCE: I have a Badger 5
There should be a reset button (circuit breaker) on the bottom of the unit. It sounds more like the blades are stuck. Pull the plug on the unit and use an allen wrench on the manual blade turner on the bottom of the unit. If the blades are stuck, you will have to try and loosen them with the allen wrench. If you do get them loose, the question then is what was holding them. Could be debris in the ISE or something broken like a blade. Keep the unit unplugged when working on it.
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Anonymous
  • 43501 Answers
  • Posted on Jan 16, 2011
SOURCE: I have an Ace Hardware
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
A
Anonymous
  • Posted on Apr 17, 2011
SOURCE: my badger 5 garbage disposal
When the motor goes bad, it begins to slow down until it stops.
That can happen suddenly, and now each time it hums, the motor is overheating and will never come back to life.
I wrote ez replacement step from days I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Why my disposal won't turn off
Sounds like the disposal is plugged into the wrong outlet. Try moving to the other socket on the wall plate.
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Garbage disposal hums but does not work
Use broomstick handle to free cutter blade
replace disposal
Gene
h
2answers
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Top Garbage Disposals Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Garbage Disposal Expert? Answer questions, earn points and help others
