All cooling/heating appliances must have a functioning device to control the rise and fall of temperature.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
SOURCE: Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
SOURCE: freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
