Coffee Makers & Espresso Machines Logo
Kim McFarlane Posted on Oct 08, 2017
I have a delongi magnifico pronto I used it today and when I press cappachino it froths milk for a lil then seems to loose suction
5 Related Answers
Anonymous
  • 515 Answers
  • Posted on Jul 11, 2008
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Anonymous
  • Posted on Apr 12, 2009
SOURCE: Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Sergio M Perez
  • 39 Answers
  • Posted on Dec 31, 2009
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Anonymous
  • 21 Answers
  • Posted on May 08, 2010
SOURCE: Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
Dane1234
Dane Ericksen
  • 25 Answers
  • Posted on Jun 29, 2010
SOURCE: CAPPACHINO SETTING NOT FROTHING MILK PROPERLY
Make sure the milk lid is thoroughly clean and that hot running water flows through the openings freely. Make sure you're using 2% milk. Make sure it's cold 2% milk. If you're already done those things, it's probably a bad "coupler unit." That means sending your machine to a service center. In that event, I hope that your machine is still under warranty. This is what happened to my ESAM3500. The good news is that I got my machine back, with a new "coupler unit," in just one week, and now I am back to "like new" cappuccinos
My delongi coffee machine smells and tast of burning the milk froth you can tast and smell it.What could the problem be and can it be fixed Regards Julie
Hi there it could be that the thermostat or sensor not working right, yes it thermostat or sensor yes can be fixed if you can fine some one that can do it for you with the right parts.
Take care All best. Clive
THE FORTHED MILK NOT HOT
Try steaming less actual milk and allowing the froth and expansion to make up the volume you need for the size of the cup. This allows you to steam the milk longer achieving a hotter froth.
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
2helpful
2answers
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
3answers
Seaco Odea Go
You can not adjust the amount of this.
/Mirran
Top Delongi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Delongi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
