Question about Dell Office Equipment & Supplies
117-363 error on dell 3115
Hi when i turn on my dell 3115cn printer it shows the 117-336 error on it's LCD panel
    New Friend:
  • 15 Answers
SOURCE:
  • 93 Answers
SOURCE: error code 336
try and remove the ink and give the heads a good clean
also look into the well area of the printer and dowse it out
with some tissue papper
once its clean as best you can then try the ink in again
hope this helps !
Posted on Nov 10, 2007
  • 564 Answers
SOURCE: Error 336
hmmm...ok...then it appears that your drivers are shot..you know how to remove them, from PC, download new ones, and re install?
Posted on Aug 18, 2008
michael_grey
  • 365 Answers
SOURCE: Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Posted on Jun 17, 2009
SOURCE: 3115cn Dell laser Printer
I've had this happen a few times. Each time all it has taken is to clean the ADF scanner glass, located on the far left side, using a lint-free cloth and a glass cleaner. I know it might seem odd because it works fine with black and white copies, however this has always done the trick. I'm surprised this is not listed on Dell's support pages. Hope this helps.
Posted on May 25, 2010
la_indomable
  • 110 Answers
SOURCE: My Dell 3115cn printer gives the error 093-921
DELL.COM
Posted on Oct 17, 2010
How to solve this error code 062-360 in Dell 3115cn printer during using it?
The scanner head is probably locked. There should be a blue switch in the left back corner. Try switching it to the unlocked position.
Apr 16, 2016 | Dell 3115cn Multifunction Color Laser...
How can reset all setting dell 3115 cn
"Here is what I did to reset the Dell 3115cn Laser Printer. In the users manual for the 3115cn in section 6 "Changing System Settings" "Resetting Defaults" refers to page 64 where it says, " For more information, see "Reset Defaults" in the User's Guide. Only I did not get a User Guide with my Dell. So I Googled "3115cn user guide" and downloaded it to my desktop and then went to Resetting Defaults. In the attachment "Initializing NVRAM for Network Settings" is what I did. Hope this helps someone else."
May 07, 2014 | Dell 3115cn Multifunction Color Laser...
Dell MFP Laser 3115CN Printer Getting an error 016-302
Remove the existing printer and drivers from the PC. Power the PC off (don't just restart) wait a few minutes (or pull the plug for 30 seconds). Reason to pull the cord, you want it to flush any buffers that might still hold printer information.
Reconnect, once on, reinstall the printer from scratch. That should put a stop to the error.
May 01, 2014 | Dell Printers:Dell MFP Color Laser 3115cn
Removal of paper stuck in a dell 3115 fuser?
It's best to remove the fuser to get access to it. This video will show you how to remove it, and which levers to move to release tension in the pinch roller to clear the jam http://www.youtube.com/watch?v=UjyggtF8d1k After you remove the jam make sure to do a close inspection on the internal roller (use a flashlight). You're looking for any scratches or "dents" in the colored roller (sometimes a deep red/brown color sometimes blue) if there are scratches you are probably going to have to replace the fuser. The imperfections on the fuser roller will show up on your printed pages. If you do need a new fuser you can find them for $160, or the entire rebuild maintenance kit for $375 http://www.fastprinters.com/productdetails.asp?PRODUCT_ID=DELL-UG190
Dec 19, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Keeps telling there is a paper jam
This particular 'paper jam' error on the Dell 3110/3115/3130 can often be caused by the paper not being picked up from the paper tray. The printer 'expects' to 'see' the paper pass various sensors during it's path through the printer. Each one has a 'time window'. If the paper is not seen to pass sensors at the correct timings, a paper jam is assumed.
Now - to cure the problem.
Just cleaning the (3 identical) pickup/separation/feed rollers in the paper tray area could be enough (they get a build-up of paper dust - can affect their effectiveness).
One of these rollers wears much quicker than the rest, and gets a pronounced flatspot. Replacement rollers are available via 'that' well known internet auction site.
Feb 05, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Dell 3115 scan without cartrige
Get a stand-alone scanner or the ink and fuser. The multi-function printer will report a fault to protect itself until the ink system is set up to be able to print.
Since this is a Laser printer, if you do spend the money on the toner cartridges and fuser, it will be a one-time purchase if you do not use it for printing.
I wish that I had better news for you.
Apr 30, 2012 | Laser 3115cn All-In-One Printer
Open Questions:
199 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
