Contact Pogo Technical Support at 302- 857- 0786
#PogoSupport
#pogosupport
#pogotechnicalsupport
#pogocustomercare
#pogocontactnumber.
Pogo com Down or Just Me
https://www.java.com/en/download/help/pogo.xml
Pogo com Wikipedia
http://www.pogo.com/club-pogo
The first two links are simply to check whether you are having access problems to the web site or have installed the java version required. The next link provides background information on the site that may give you a clue as to your access restrictions. And the last link is to the membership page. Good luck.
pogo customer service 1-845-582-1921 pogo Customer Service Phone Number/362 pogo phone number usa
SOURCE: club pogo closes when i try and play
hi,
Might be it needed some Active X controls to download and install on your browser and your security settings are HIGH.
however, if you are using IE to open, try again with Mozilla firefox.
Please make sure that you have latest Flash player installed for browsers.
Thanks.
It sounds like a internet browser problem almost sounds like a java problem,
Go to java.com and click the blue Free Java Download button. This will allow you to update your java clients (pogo users Java)
Also go to www.flash.com and update your flash, if you see a movie play when you go to flash.com you do not need to update. If you don't click, install
If the above does not work , try downloading an updated web browser either IE, Firefox or Chrome - all the links are provided below. Once you update your browser try again.
You can also Download IE 8 from http://www.microsoft.com/windows/Internet-explorer/worldwide-sites.aspx
Or Firefox web browser from mozilla.org
Chrome; http://www.google.com/chrome
Thank You
SOURCE: I payed for club pogo and cannot get it
I could not play pogo on Mozilla and had to get on thru Netscape. Just a suggestion.
SOURCE: I am a lub pogo member sice 2004 and when I cick n
Hi you need to contact the system administrator from poxo and ask him to reset the permission I expect this will fix things? In any event you can then explain what's happening and they will help. As an aside here try removing the cache and cookies an or using another browser, this too may help, as it simply maybe using old settings?
