SOURCE: my nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
SOURCE: 7" sunpak frame wont recognize usb connection
How do I get my computer to recoginze the connection of my USB?
SOURCE: usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
SOURCE: Nokia 6500 slide. Device Not Recognized
If you go to Control Panel -> System -> HardWare and check USB controllers which shud give you a list of all USB ports. Below that you will find Wireless Communication Devices. In this you shud find all the modes your phone is installed as. Check if all these settings are present. Secondly, install PC Suite now that you have restores the system to an earlier date. Connect the phone and connect.
SOURCE: My computer wont recognize my BB Curve when its in the USB
Download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8330 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=02A32AD2669E6FE298E607FE7CC0E1A0&dl=536515EC27684D1C723C2362546FD6C4
Just fill out the form and the download is free.
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
