Question about Razor E100 Electric Scooter
I have a Jetson 48 volt 500 watt bike/scooter, I replaced the Controler and when i turn the key on, the mother run by itself .Can any one tell me what I did wrong..
How do i increase the speed limit on my jetson beam scooter?
any faster and you risk serious injury to yourself and others
if you want to go faster , buy yourself a proper scooter and get a licence
Nov 22, 2017 | Cars & Trucks
2013 taotao 48 volt 500 watt electric bike. All
https://www.electricscooterparts.com/troubleshootingmotordoesnotruncharged.html
Sep 25, 2014 | Motorcycles
Where can I get the 48v 500watt bushless motor for my e wheel E36 3 wheel electric mobility scooter
500 Watt 48 Volt Electric Scooter Motor
This link shows a 48 v. 500 watt motor, but you should contact them to make sure the motor fits your particular scooter. I hope this helps.....
May 01, 2014 | Health & Beauty
How to charge the batterys
Hi , i thought the charger socket was located on the handlebars or nearby on that model, if not there might be a panel under the seat ..
Regards
Rob
www.gewizrepairs.co.uk
Feb 26, 2014 | Rad2go EV3 Three Wheel Electric Mobility...
Electric Bike Battery Basics: What are these Volts & Amp Hours?
Volts - Watts and Amps are the gasoline of an electric bike. Ohms law comes to play here. If we were talking about water - Where Volts = pressure - and Amps = volume ... Watts are the measure of actual work done. Does this make any sense to you ??? A bike that claims to run of 48 volts ... means nothing. A bike that says it runs at 50 amps ... means nothing ... a Bike that says it sips watts ... means nothing.
Think in these terms ... a battery is rated in Amp hours. That a given battery rated at 1000 amp hours ... is capable of delivering 1000 amps of power for one hour before it is discharged. Conversely, it can deliver one amp for 1000 hours - or any calcuation in between. Watts is the actual measure of work. I suggest you bone up on Ohms law here ... http://en.wikipedia.org/wiki/Ohm's_law and http://hyperphysics.phy-astr.gsu.edu/hbase/electric/ohmlaw.html. there are lots of other references. What does the electric motorcycle you are looking at claim is the watt consumption??? Can the battery supply the power you require for your riding activity? How long does it take to fill the "gas tank" with watts before you can do it again?
\I hope this answers your question ... if not ... please ask again.
Thank you for using FixYa.com
Dec 14, 2012 | Motorcycles
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
Razor E100 Electric Scooter Logo
37 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
