Downloading operating instructions from a line 6 amplifi 30 guitar amplifier to apple iPad Pro .
SOURCE: amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
SOURCE: Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
SOURCE: need instruction manual for a Fender 15g combo
Here is the page you need:http://www.fender.com/support/amplifier_schematics.php Look under hard copy archives if you can't find it in the newer section. I emailed them at [email protected] for a manual and schematics for a Fender Sidekick 10 and they emailed me one right away and were really nice. Please let me know if this helps.
SOURCE: Have Line 6 Variax 700 6 String Modeling Guitar
The frequency of the A string when in tune is 110Hz.
What you are hearing is actually 120Hz which is the second harmonic of the 60Hz power frequency. It would be hard for you to distinguish between 110 an 120.
Try this test: Bring something that produces a reasonable magnetic field such as a wall wart power adapter that is powered near your pickup... Then you will be able to see that you are picking up stray magnetic fields from your environment.
Humbucker pickups attempt to quash such pickup by winding the pickup so stray magnetic fields cancel in adjacent coils.
Some pickup CAN occur on your cord and also in an amp.
If you leave your cable unplugged from teh guitar you are LIKELY to pick up some of this hum... The second harmonic pickup is COMMON when devces like full wave rectifiers are driven by transformers in the area.
