Dropped tv has white lines curved looks like a big elephant
SOURCE: I have a Samsung 48" curved ultra 4k HD TV that has a red light blinking 6 times what does that mean
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
SOURCE: my bauhn 49 inch 4k ultra HD smart tv races over all menu items what can be causing this??
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Where is the power button on a Hiscense 4K ultra HD tv?
http://support.hisense-usa.com/support/manuals.asp
Here is the Hiscense manuals you will have to enter your model or serial Number. Then you should be able to view the info you need.
