SOURCE: How do you uninstall Chromebook updates?
you could look at the uninstall programs in control panel to see if any chromebook updates are there for uninstall Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error. 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. hope it helps
or use the system restore to restore your computer to a time before the updates where installed or another time
You can use the System Configuration utility to perform a system restore. There are three possible restore points: System checkpoints that Windows schedules
To perform a system restore, follow these steps:
SOURCE: how do I download pictures from my Samsung pl20 camera to the acer chromebook 11
Try this Google Groups
The pertinent answer is from Caver_tim
"I take the SD card out of my Camera, plug it the card reader in my chrome book, or use a USB card reader.
view the photos,
View the card using the file explorer (should pop up automarically or press Ctrl+M)
copy them to the local storage if i really want
copy them to an external USB haed [sic] drive"
(This is only relevant if your Chromebook 11 has a card reader. The HP one does, apparently)
[for Windows computers see p87 of the manual
http://www.camera-usermanual.com/manuals/samsung/Samsung_PL20.pdf - when I connect my camera {not a Samsung} to my PC it can search the internet automatically for the appropriate drivers/software so you may need to ensure that your chromebook is connected to the internet ? But, the manual says nothing about working with Chrome OS]
8.February.2015
SOURCE: can i purchase a printed manual for acer chromebook 11 cb3-111
Here's the PDF Manual link, if you have a printer just print it, or save it to your Laptop by right clicking on the link and save as or save link as (whatever name) to your desktop or downloads folder.
http://www.lpmanual.com/manuals/acer/Acer_CB3-111.pdf
Hope it works out for you.
