This code means toner mot fail so check for toner caking after that go mvm location 762-032(write down current val just in case) whatever value ...A Hard reboot might be needed shut it down an turn up after 5 minutes
Thst is a hole punch home position sensor not detecting the 2 or 3 hole punch.
Try reseating the hole punch assembly then power the machine off and on.
That error points to a fuser problem. Replace the fuser and see if that works for you. If not then you need some add'l parts and a service tech to install and repair it for you. Hope this helps.
