Health & Beauty Logo
J
Jerome Pogue Posted on Oct 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY QUESTION IS ABOUT BATTERY POWERED ELECTRIC SCOOTERS. WHY IS IT THAT i AM NOT GETTING NOWHERE NEAR THE RANGE that I am getting from a fully charge scooter.
At first Im getting unbeliveable power, and speed and then after a very short time the battery is almost dead. its been that way since the first day I got the scooter. Im supposed to get 30 miles when fully charge, I lucky if I can get 3 miles, before I have to recharge.
Dan Apthorp
Level 3:
  • Electric Master 2,824 Answers
  • Posted on Oct 03, 2017
Dan Apthorp
Electric Master
Level 3:
Answers
2824
Questions
0
Helped
889897
Points
7391
Sounds like either the battery or charger is not working properly. If the machine has been sitting around for a long time without charging the battery then the battery may not hold a full charge, I would pull the batteries and have them checked out and see if they are charging up to snuff. Fully charge them before you get them tested. There should be no charge to check them.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 20, 2008
SOURCE: BATTERY dead. how to charge?
The battery is removable and the camera came with a charger that you connect the battery to and plug into a household socket.
Q4SteveB
  • 159 Answers
  • Posted on Mar 17, 2009
SOURCE: dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Anonymous
  • 945 Answers
  • Posted on Nov 06, 2009
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Anonymous
  • Posted on Jun 17, 2010
SOURCE: I own a 2007 Yamaha R6 with 2,000 miles and a dead
If the battery was dead for a decent amount of time, it's shot. But if it's not the battery and you checked the stator without issue, check for a ground. Another common culprit is the alarm if you have one. I have Lo-Jack and a scorpio alarm and it drains my battery pretty fast, as in just days if the alarm is on and all options in use (perimiter, shock, tilt, etc. but especially perimiter)
Anonymous
  • 3085 Answers
  • Posted on Jun 27, 2010
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
1helpful
2answers
I lost a indicator light on my mobility scooter and now the battery runs out quickly
Are you losing battery fast with your electric scooter? What a pity! It should have been hard for you to run out of juice in a middle of a commute or lose steam just when you are about to have fun. Such is the downside of electric scooters, electric cars, electric motorcycles, and electric mobility devices that are powered by rechargeable battery. They seem to have the power of a flashlight, but as rechargeable devices, they should have more power than a flashlight. How could you be losing battery fast? You now at least relate to other motorists whose vehicles give away in the middle of the road, and without a refilling station or repair shop in sight.
Why you're losing battery fast
Why is your electric scooter losing battery fast? Something might be wrong with the battery pack or that something in your unit is rapidly depleting your power source. Maybe your charger is defective or not powerful enough to charge your e-scooter. Or the way you operate your unit over certain terrains could be the reason why your unit is losing battery fast. You cannot just say your retailer have sold you an e-scooter with a defective battery.
Done charging but your electric scooter does not start? What if it has no power at all? Think your e-scooter has been properly charged? There might be a broken or loose connection or two in your unit.
Limited power for short distances only? The battery could be faulty or has incomplete charge cycles. Or you either have a defective charger or an old battery. As a battery ages, its capacity decreases, as you should know. If you have the same battery for years, there is no wonder why your e-scooter is losing battery fast.
Charging done for the full required time (usually 6 to 8 hours), yet the electric scooter is still not indicating a full charge? You may have a faulty charger or a bad battery. You should also be wary about a battery that charges faster. If it takes long for an electric car to fully charge, how much more an e-scooter? Anything could be behind your unit losing battery fast.
Battery information
When you buy an electric scooter, be it be a two-wheeler or three-wheeler, always check the specs of the battery pack. Pay attention to the battery voltage and amp hours (AH), not just the chemistry (lithium-ion, sealed lead acid, or lithium-polymer).
Batteries of e-scooters are typically configured in 24V, 36V and 48V. Higher voltages e-scooters are generally faster, but there are factors that could affect performance, notwithstanding battery power, such as rider weight, terrain, and the efficiency of the unit's motor and drive system. One or two of these factors could be behind your e-scooter losing battery fast.
AH is as important as voltage. AH is the measure of battery capacity, an indicator of an electric scooter's range.
One three-wheel electric scooter (on a 300W motor) goes 12 mph and travels a maximum distance of 15 miles per charge of a 36V 7AH battery. Another three-wheeler (on a 250W motor) attains a top speed of 12 mph and a maximum range of 28 miles per charge of a 48V 10AH battery. A two-wheel electric scooter (1000W motor) goes 24 mph and has a maximum range of 10 miles on a single charge of a 36V (three 12 V) 12AH battery. Another two-wheeler (350W motor) has a 36V 10AH battery that ramps up a maximum speed and range of 18mph and 15 miles, respectively, on a single charge. Different electric scooters, different battery specs, different performances. Results may vary.
Knowing your e-scooter's battery (and the other components) is knowing your e-scooter well. That way you will have an idea why your unit is losing battery fast-and how you can troubleshoot it.
How not to lose battery power quickly
As owner, you can do preventive maintenance to avoid losing battery fast and ensure optimal performance of your electric scooter.
  • If your e-scooter has no power after a required full charge, check for any broken or loose connection. Remove the top or deck to reveal the wiring. Inspect the battery pack, switch, brake lever, throttle, and controller. Unsure? Take your unit to the retailer or service shop for check-up.
  • Give your battery a full charge. This will help your electric scooter avoid losing battery fast. Most batteries of e-scooters take up to 8 hours for a full charge. However, do not overcharge for more than 12 hours as this could possibly damage the battery. Charge your unit according to the required duration as specified by the manufacturer.
  • You can prevent losing battery fast by simply replacing it. Replace battery if you begin to notice a gradual decline in charge life. Moreover, replace an old battery with a new one.
  • It is also possible that newly installed batteries could rapidly lose their storage capacity. Have a licensed technician perform a battery test to determine current capacity. Avoid losing battery fast with professional assistance.
  • Don't leave battery uncharged for a long time. Any battery that is left uncharged for over six months becomes defective. You won't be able to successfully recharge a battery that is left uncharged for months. Charge before storage, and when in storage, charge every 30 days.
  • How to know if your battery is getting charged? Check for the indicator light on the charger. If it does not illuminate, battery is not getting charged. Get yourself a new charger.
  • Test your charger's output Voltage with the use of a multimeter. The output voltage should be a few volts above the charger's rated voltage (24V, 36V, 48V). If output voltage is zero or below the rated voltage, charger is defective.
  • Faulty charger port could be another reason why your electric scooter is losing battery fast. Test your e-scooter's charger port by plugging the charger into the port. Look for an illuminated indicator light on the charger. If indicator light illuminates once the charger is plugged into the e-scooter, this means the wires and wiring connectors going to the charger port are in good condition. The charger port is working properly.
  • You can also perform a battery test while operating your e-scooter to see how it is losing battery fast and how long the battery lasts. Give your battery a full charge first, and then drive at full throttle on flat terrain. Most e-scooters will have a range around 30-50 minutes on flat terrain. Battery is already worn-out and in need of replacement if it lasts less than 30 minutes.
  • Another way to check if your e-scooter is losing battery fast is to test the battery voltage, same way you test your charger's voltage with the use of a multimeter. The battery should be above its rated voltage level even if it has been in storage, has been driven or fully discharged and sits for a few minutes. If not, battery may be worn-out or defective. This calls for replacement.
  • Do not attempt extreme stunts with your electric scooter or risk losing battery fast. Though many e-scooters are durable and built to support heavy weight, the metal frames, wheels, and other components are unable to withstand extreme riding activities.
  • Do not drive e-scooter over water or else your unit will start losing battery fast due to battery's contact with water. If you do ride through water, dry unit and battery completely before storage.
  • Do not drive over uneven or rugged terrains. Though some e-scooters are designed for off-road use, uneven or unpaved surfaces can still cause stress on the parts and components. Drive without care over challenging terrains and your electric scooter will start losing battery fast.
Celebrity xl looses power when climbing slope my batteries is fully charged and it still hesitates to climb
Your Scooter Manual will tell you what percent grade the scooter will climb. If it is too steep, it may stop because the motor is getting too hot. The Motor will be using more battery power to climb slopes so you may experience a pause, that would be normal.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Just bought one of these and it seems like it doesn't hold a charge it goes pretty good and thanafter 15 mins so slow??
Battery powered vehicles like scooters and golf carts have trouble going up hill because smaller electric engines aren't powerful enough or made for nothing more than flat land. You could have a bad battery or the battery isn't being charged enough. I know someone that has a golfcart and it takes approximately 48 hours to charge full. You may want to check the manual about charging times.
2answers
My wispa scooter is losing power even when battery is fully charged, can you suggest anything?
Charge your battery's like you normally do then get you a load tester and check your batterys ,You may have a bad battery. Your welcome
The scooters won't start although lights and horn workd
mcdevito75 here, Is the battery fully charged, if not, Charge battery, if Charged double check connection at battery and motor.
1helpful
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
2helpful
4answers
Electric scooter Troubleshooting
A small tip here - bigger is better. The large diameter wheels clear gaps in concrete or pavement that would hang up a skate wheel or a scooter with smaller wheels. Most electric scooters also handle well in gravel and small terrain features. We don't recommend slamming electric scooters into a curb to get over it like some people do with their bike. This could result in damage to the electric scooter. Simply Ollie up a curb and keep going.
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
SmartAviator
SmartAviator
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
