SOURCE: My Briggs & Stratton gives off a puff of blue
Sounds like you may have too much oil in the engine. Check your oil level.
SOURCE: Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
