SOURCE: CMOS Error 0193
The security device plugs into the left front of the MB as viewed from the front. It is approximately 1.5" x 2 inches in size. they sometimes come loose form the socket when a system is moved. Open the case and see if it is there and loose. If completely gone, then you need to contact your MB supplier for either the device, a new board or a factory reprogram of the board to disable the missing device.
SOURCE: system halted
Operating systems needs a tune up.If the same happens in safe mode then OS needs to be reinstalled.
SOURCE: My DELL Workstation 670 says
Maybe the memory is the wrong type or is too big (too many Mb for one slot).
Check your Motherboard specs or goto CRUCIAL.COM and run their SCAN MY COMPUTER program to see the max memery size for pc and for each slot.
Good luck and please post back with your results.
SOURCE: i was install windows 7
Hi, welcome to FixYa.
May I know what your graphic card is? Sometime incorrect driver can lead to this situation too.
1) ALL power removed, AC adapter (Charger), and Battery
2) Lay a soft cloth down on the table you are working on.
(DO NOT work on a bed, couch, or directly on a carpet floor. HIGH areas of Static electricity)
Lay the Dell Notebook PC upside down on the cloth.(Helps prevent scratching the notebook, and the table)
3) Remove all Ram Memory module/s. ('Stick')
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/memory.htm#wp1180190
[From,
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/index.htm ]
Handle the Ram Memory module by the BODY.
The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Use a pencil eraser to clean the contact pins. ALL pins, BOTH sides.
If you are using a pencil eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub up, and down on each contact pin. Doesn't take much pressure, nor rubbing to clean them.
In fact when you are done the contact pins may not be bright, and shiny.
It's okay I assure you that you have cleaned them.
(Doesn't take much 'corrosion' to make a bad contact surface)
Use air to remove the eraser dust. If you have a can if compressed air available use it. (Also use on the ram memory slots)
If not air pressure from your mouth will be sufficient.
Reinstall all Ram Memory modules.
Reinstall the Battery, and then plug the AC adapter in. (Then plug the AC adapter into power)
WAIT 1 minute, turn the laptop on.
For additional questions please post in a Comment.
Regards,
joecoolvette
just remove all memory modules and start server ... yes u will not get display but let it process ..wait for 10 min and than power off .. now re-install memory module ... it will work ...
System Halted : No Memory could be configured
update bios it's work good
Remove memory restart the system after 10min. Shutdown the system and installed the memory it will run.
System halted : no memory could be configure
