Video Cameras Logo
Carol Wegener Posted on Oct 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do transfer video from camera to MacAir
Do I need a firewire cord or usb cord to connect from Handycam Digital 8 to my Mac Air
Janet Lauren
Level 1:
Habit-Forming:
New Friend:
  • Contributor 13 Answers
  • Posted on Dec 19, 2017
Janet Lauren
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
13
Questions
0
Helped
2940
Points
89
Well, follow the tips below to transfer your videos from camera to Mac Air:
  1. Use a FireWire cable to connect your video camera to the FireWire port on your Mac, then turn on your camera.
  2. Download and install Mac video converter from Cisdem, and then import your videos via click the Media Library. There you can see the connected camera.
  3. Select the videos that you want to transfer to your Mac Air.
  4. All the videos now are imported to Cisdem Mac video converter. Select your desired output video formats.
  5. Click convert and then all of your videos are on your Mac Air and you can enjoy them any time.
https://www.cisdem.com/video-converter-mac.html
Ron Durham
Level 3:
Master:
  • Master 508 Answers
  • Posted on Oct 03, 2017
Ron Durham
Master
Level 3:
Master:
Answers
508
Questions
Helped
150235
Points
1661
You will more then likely need a converter cord for it to work .Try taking them to walmart an see if they can match the cord needed or order from a computer store online like tigerdirect...Good Luck
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Sep 06, 2005
SOURCE: USB 2.0 vs. Filrewire - video to PC
Hi I have figured it out. Even if the USB 2.0 is faster than the firewire the camcorder itself do not transfer at the optimal speed when connecting with the USB (even id the USB can transfer faster). So the only fast transfer option is the firewire
A
Anonymous
  • Posted on Apr 23, 2008
SOURCE: sony handycam DCR-HC26 and mac not recognizing with firewire
mlkml
Anonymous
  • 203 Answers
  • Posted on Jun 06, 2008
SOURCE: connecting to computer
you both need to use a firewirecable to download video-not usb-the camcorders always have a 4 pin connection and you will need a 6 pin on other end for mac or a 4 pin for window laptops-also use 6 pin for most desktops-when buying cable ask for 4 to 4 or 4 to 6 pin firewirecable-imovie should be fine in windows use movie maker which is in windows already under program menu-says dv on cam to connect-make sure you have firewire port on computer also-if not add a card to include one
Anonymous
  • 216 Answers
  • Posted on Jul 01, 2008
SOURCE: Canon ZR950 video transfer problem
Greetings reubnick,
Unfortunately, the Canon Z950 only offers transfer to your pc via firewire (Firewire/IEEE 1394 DV Terminal). Therefore your computer would need to have a firewire port.
One other option is to utilize a standalone system to plug your camera in to transfer video. Here an example of one unit: http://www.bestbuy.com/site/olspage.jsp?skuId=8470923&productCategoryId=abcat0504007&type=product&tab=1&id=1184768699303#productdetail
I hope this helps!
Dorothy
Go Ahead. Use Us.
Anonymous
  • Posted on Nov 16, 2008
SOURCE: how to transfer video from a sony handycam 105e to a pc
I solved the problem by searching the internet until I found the programme that fixed my problem.
Do you make a firewire compatible with Handycam DCR-DVD105E and a Mac pc? Mac does not support minidiscs. I also have an external minidisc drive which allows me to play the discs on the Mac but I want to...
If you can "play" the minidisc into the Mac, it should be possible to "copy" the files onto the Mac's disk-drive, at maximum-speed, rather than playing them in "real-time" mode.
The Sony MZ-RH1 mini-disk player allows "digital" file-transfer of the contents of minidisks into a computer, through a USB (not Firewire) connection.
1helpful
I have a sony handycam dcr-pc101 ntsc and I am trying to connect it to my Mac, but the computer will not recognize the movie camera. (I have it connected through the firewire connection- not the usb port)
I'm osrry that you find difficulty in transfering the videos to the macintosh computer. Refer the URL for the infirmation on Transfering video to a Mac computer
http://support.sony-europe.com/tutorials/dime/videotransfer/vtransfer.aspx?site=odw_en_GB&sec=DV&m=DCR-PC101E
NOTE: The procedure to transfer video to a computer will vary depending on the type of camcorder you have and the type of connection you are using.
I cant transfer my videos from sony handycam dcrhc36 to my computer os window 7 evenafter downloading pmb from sony sitemy computer is not detecting the handycam
You don't say what type of connection you are trying to use. This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable. Confusingly, Sony call Firewire "i.Link".
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Can i transfer the video to my pc from my sony handycam dcr pc120?
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
I'm looking for the driver of sony handycam CDR-TRV22E so that i can transfer the video to my pc. thanx.
You can download drivers and manual for this camera from this page.
Advice on how to do the transfer is on this page. (You need to select Mini DV)
Sony recommend using Firewire instead of USB to transfer video from this type of camera.
This camera has both USB and Firewire (DV) connections. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
2answers
Connecting to computer
if it's a digital 8 like you said you should use a firewire cable to stream from cam-your cam has a dv port on it if it is digital-this is 4 pin firewire end-if your laptop or desk has same connect your fine-laptop has same sive end-desktop or mac has larger 6 pin end-if not use a box by pinnacle called dazzle that will convert your video out to usb-use windows movie maker if you want to work with video it's in xp or vista already installed
1helpful
3answers
Importing from Sony Handycam trv350 to iMovie
I have a TRV730, and on this camera the USB port on the camera only reads files from the memory stick. (Set the camera mode switch to "memory", and the Mac will display the contents within about 20 seconds.) Same as any digital camera.
Video in/out is only done through the firewire (iSight) port. You need to buy a 4-pin/6-pin firewire cable. Good ones are $25 or so, cheap ones can be had for $5 or less but you take your chances with those. (Can anyone explain why Sony includes a useless 4-pin/4-pin iSight cable with the camera??)
What's cool about the Digital8 cameras is that you can put in an old analog (Hi8) tape and output a digital signal to the Mac.
Can't be 100% certain of this, but I'd bet your camera is similarly configured. Squeezing video through the USB port would be painfully slow anyway.
1helpful
Firewire
Yes, you can capture camcorder video from a miniDV camcorder using a FireWire cable and video capture software. Your computer came pre-installed with Windows Movie Maker, or iMovie (if you are on a Mac).
FireWire, IEEE 1394 and iLink are all the same thing. There are 4 and 6 pin FireWire cords. My guess is that you need a 4pin to connect to your camcorder and a 6 pin to connect to your computer. But it all depends on what ports you have available.
You can get a FireWire cord for less than $10 at most computer electronics stores
Check out this FireWire guide for more information:
http://www.stashspace.com/video-editing/firewire-guide.stm
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
