Water Heaters Logo
E
Elaine westgate Posted on Oct 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water heater is leaking I need to drain it how do. Do that
Roy McCracken
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Oct 02, 2017
Roy McCracken
Expert
Level 2:
New Friend:
Answers
59
Questions
0
Helped
30775
Points
137
Turn Off Power or gas to heater, shut off incoming water supply, open the hot water side of a nearby faucet, attach hose to bottom drain valve, open drain valve, drain tank. Opening faucet should stop it from becoming vapor locked.
1 Related Answer
HANK MCNEIL
  • 252 Answers
  • Posted on Sep 18, 2009
SOURCE: Water Heater drain leaks and has caused rusting on tank
If you're sure it's the DRAIN, just get a garden hose cap for it (your other option is to replace the valve - drain tank, replace valve, refill).
NEVER CAP THE RELIEF VALVE DRAIN!
Gas water heater sets on a stand and there is a drain in the middle that leaks when we use hot water how do I fix it
TP valve is dripping? Or drain valve is dripping?
Or water heater is rusted out?
http://waterheatertimer.org/Leaking-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
1helpful
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
How do i drain a water heater
What kind of water heater do you have?
Tank, tankless, under-counter, portable, solar?
If you have ordinary tank-type water heater, then open drain tap at bottom of heater.
Be aware also that older heaters, the drain valve will possibly leak afterwards and you will need a garden hose cap over the valve.
http://waterheatertimer.org/Water-heater-will-not-drain.html
I just noticed that my hot water heater that is 6 years old is dripping very slowly from the bottom faucet, how can i stop this leak. thank you.
If you mean the drain valve, then buy garden hose cap at home center.
Cap will have rubber washer that seals tank.
If drain valve is plastic, the cap may not thread on without sanding down end of plastic drain valve.
Otherwise replace drain valve, which is simple if drain valve is brass, but can be difficult if drain valve is plastic.
Turn off power to water heater: Electric: turn off circuit breaker. Gas: turn knob to pilot.
Turn off water, open bathtub spigot on Hot side, drain water heater, remove drain valve with wrench.
If plastic drain valve breaks while being removed, then 'gently' break out broken part using hammer and big screwdriver.
Buy new drain valve at box store in water heater department.
Put teflon tape on new drain valve threads.
http://waterheatertimer.org/Water-heater-is-leaking.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Leaking drain valve from GE profile water heater
well u could fx it by takeing the drain off it will come off with a little force and it will not damage the water heater and going to get a new drain from a hardware store or if u do not want to replace the drain buy a new water heater
1helpful
Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
