Sewing Machines Logo
n
norman tatana Posted on Oct 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there my juki lk 1900hs show error e7 immidietly after switch on please help
R.A. Ellis
Level 3:
  • Juki Master 12,731 Answers
  • Posted on Oct 02, 2017
R.A. Ellis
Juki Master
Level 3:
Answers
12731
Questions
Helped
2613543
Points
59176
Search for:
Make Model error E7
3 Related Answers
abozid
TCHNICAL SUPPORT FOR JUKI-JACK-PEGASUS
  • 180 Answers
  • Posted on Oct 08, 2010
SOURCE: how many ampere trafo for
hi there
can you explain you qustion by more clear information, i can help becuse i had more experiance with juki LK1900 machine ( mechanic and electronic )
best regards
ashraf abozid
[email protected]
Anonymous
  • Posted on Apr 14, 2011
SOURCE: need a juki lk-1900 ahs instruction manual
Catalog No. Machine Brand juki lk 1900
Raj Patel
  • 1042 Answers
  • Posted on Mar 22, 2016
SOURCE: What does error A7 mean on juki lk-1900 AN sewing machine
See manual here:
http://www.juki.co.jp/industrial_j/download_j/manual_j/ip200/LK_English.pdf
All error codes begin with 'E'?
Testimonial: "thanks :)"
Hi We have JUKI AMS-210D and facing problem in no display. Error code 100, 101, 104 comes we check cable J14 fuse every thing. Anyone can help.
Have you researched what the codes signify? That will give you a good clue of what's going wrong and how to address each. In your case, since you are having multiple issues, service may be a good option.
According to this link, it means a board problem:
How to solve error 100 in JUKI LK 1930 bartacking machine some time will...
What does error E7 mean on juki lk-1900 AN sewing machine
turn off the power switch and remove the cause of problems
1helpful
Juki lk1903b machine is not working E7 is appers
HI
regarding JUKI LK-1903B Eror E7:
1-Machine lock error ( The main shaft of the sewing machine does not rotate due to some troubles ). please check if machine rotate smoothly by hand or not.
2-main motor problem ( AC servo motor problem ) motor part No.:401-38137.
3- check connection CN-15 / CN-17 from SDC board to main motor.
4 - problem in SDC servo board ( No output for main motor ). SDC servo board part No.:401-42267.
best regards
ASHRAF ABOZID
[email protected]
CAIRO - EGYPT
How to solve error 100 in JUKI LK-1930 bartacking machine? some time will come error 104.
Hi Indika
regarding error E100,E101,>>>> to E104 means main board was problem and need to replace ( no chance to repair ). even you check all PCB by eyes you cant find any fault , just need to replace main board with JUKI part No. : M8601-593-AA0 .
best regards
ASHRAF ABOZID
technical support ( JUKI - PEGASUS - JACK )
CAIRO - EGYPT
[email protected]
Juki LK-1920 HA (Model# MC-592) give an Error E1
Hi
E1 is pattern number error-the specific pattern no. has not been registered in the data rom.-check the pattern number.
I if you have any other questions with this machine let me know- have years of experience here
2answers
How solve Juki DDL 8700 automatic single needle machine E-7 error?
hi there,
1- check V belt if there's more loose plase make it tight littel.
2- check timming cam for thread trimmer , sometimes lock after trim and E7 appear.
please advice me type for control box ? i can give more help if you have basic knowledge for electronc. just email me if you want any time.
best regards
ashraf abozid
[email protected]
CAIRO - EGYPT
1helpful
Hello. My sewing machine DDL 5550-6 display shows the problem. E7. What is it? And how do I fix it? Thank you
HI THERE
concern E7 there's many reasons :
1- machine jamd ( try to turn machine by hand if you found handwheel is move easy ok.
2- thread trimmer locked or release? sometimes E007 come at the time of thread trimming function activated.( please check timming cam for thread trimmer ).
3- sometimes some threads go insaide hook and machine stop and give E7.
best regards
ashraf abozid
CAIRO - EGYPT
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
