SOURCE: rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
SOURCE: i need a manual for humminbird wide 100 fish finder
You can find the manual you need at: http://www.humminbird.com/support/FAQ.aspx?faqid=72
It is listed in the legacy products area with the wide series of units.
SOURCE: HP Pavillion dv9000
before you spend $200 for a new lcd screen; may I interject; Please test your computer by hooking it up to another monitor if you get the same result; place your computer in the freezer for about an hour then start it as this model of computer is famous for overheating the nvidia video chip also the tiny fluorescent tube called a cold cathode has beeb found to glow red when about to fail the cathode can be purchased onlin at: laptoppartsdirect.com or, e-bay almost always the only reason to replace you lcd is: breakage or, bad pixels.
SOURCE: i bought a fish finder from harbor freight and it
http://www.harborfreight.com/manuals/94000-94999/94511.pdf
Your welcome!
SOURCE: I have a hummingbird matrix 67 gps chartplotter
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
