Here are the code for soft reset *#7380# and hard reset *#7370# nokia mobile. Hard reset delete data on your nokia e5 but it will also remove your security code and reset to default. this will unlock your nokia mobile. and it your mobile is sim locked than t-mobile unlock and at&t mobile sim unlock is different.
How to Network Unlock Att Mobile . in that case you need sim unlock code for your nokia. you can get free from online as per your imei number. even you can do bootloader unlock on your nokia mobile.
here is other way to unlock nokia mobile.
First power off nokia mobile then simalteneously press and hold power button, *,3and call button. Once nokia log on screen release all key button. This will factory reset nokia. Default nokia code is 12345.
http://mobile-cellphones.blogspot.com/
SOURCE: i forgot my security lock code of nokia 6600 how should i find it or reset it?
hahahaha! simple.. u need to have a software to unlock ur fon.. and luckily i have all u need. hehehe
SOURCE: forgot my security code in nokia 6120 classic
hi.. just go for the settings option in ur mobile.. There u can find master reset which will reset ur codes so that it wont ask for any unlock code for the next time...
SOURCE: nokia 3110c mobile, i forgot security code.now how to reset security code?
plz downlod new softwear
SOURCE: i forgot the security code for my nokia 2680 -2.
You can get the security code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call.
The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
SOURCE: I forgot the security code
I forgot the security code and the reset factory setting am using on my nokia 3120c, please I need your help
