As your watch has 3 buttons I am assuming that it has the main dial and 2 sub dials maybee to show the date. The centre button should pull out (DO IT GENTLY) and either will stop or click ,you should then rotate it to set the time, when done push it back in to start the watch running.
The 2 outer buttons probably work by pushing them in a click at a time to set there respective dials.
SOURCE: how do i set time on unlisted watch
dear sir
there r three buttons in which there r combination of buttons. your stopwatch button may not set the time . the middle button may set the time for u
SOURCE: how to set time on addidas reloj watch
One button is called the mode button. This will put you in one of the five options. Select the button that indicates time. Pressing and holding another button for a couple seconds will get a digit flashing. Once flashing a third button will make the digit change. It may also be the mode button that makes it change also. You will just have to experiment if you can't find the instructions.
