SOURCE: planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
SOURCE: Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
SOURCE: delta rockwell 22-200 planer. I need a manual.
Check on www.owwm.com. You will probably find your machine on their and resources to help you in your quest. It's a great site for old tool hounds.
SOURCE: i have a delta planer
Hi. no problem. Here is a free download of the manual you need. http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=43218&typeId=10079&documentId=29512
With new sharp blades you will find that it feeds as it should.
joe.
4 thumbs up please. ty
