A
Anonymous Posted on Oct 01, 2017
My SONY - VPL-FE40 is coupled with Polycom for VC. Rightnow the image is flickering when using local camera and complely blank when trying to connect to far site. Any idea of what the issue is?
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 23, 2008
SOURCE: Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
shyamprocom
procom office solutions
  • 93 Answers
  • Posted on Feb 08, 2009
SOURCE: VSX7000 series VC remote site cannot see the video of near end
hi
for video conferencing at such long durations over IP, it is a MUSSSST to have dedicated stable bandwidth at all the locations.if that fails, symptons like the one u experieced are possible.this will generally happen during working hours when bandwith usage by pc's is high!!!!!
shyamprocom
  • 93 Answers
SOURCE: Could not connect to our VSX 700 polycom over ASDL
for VC over IP, both end should have a dedicated bandwidth with PUBLIC IP.
this solves most of the problems that are faced in a vpn or shared network like situation!!!!
projdoc
jasbo
  • 2239 Answers
  • Posted on Dec 08, 2009
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Testimonial: "Thanks very much for the help. "
Anonymous
  • Posted on Jan 26, 2010
SOURCE: connects to far sites but there is no image, only
When i connect the other end successfully(all the blue balls color turned to green)but with only a sentence, says:"secure conference encryption 。。。"
Sony VPL FE40 BUTTON POWER green light , after standby six flashes. help
That is an internal electronic failure. Could be a ballast, mainboard, any number of things. Not a user repariable issue. http://www.projectorcentral.com/pdf/projector_manual_3594.pdf
More info is on page 47 in the manual that I linked.
How do I enter servicemans menu on a SONY FE40?
1,turn on the projector
2, press the following keys on the control panel of projector ( or on the Remote Commander) in the following order for less than five seconds each:enter,enter ,up,down,enter.
3,ok
Note: enter,enter ,left ,enter, is another way for advance Menu.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: [email protected]
Skype: lampdeng.com
http://www.lampdeng.com
4helpful
2answers
In shooting mode, lcd is blank, images are blank
I found another user's suggestion and followed it- slapped my camera on myopen palm a couple of times-and it fixed the problem! Needless to say that I will not be buying a sony camera ever again!
Canon VC-C4 vs Logitech webcam
DO you realize that this camera cost around 900 US$? - Might be a little overkill for VOIP.
Apart form that it is an excellent camera. Have look at the manual here.
The camera connects via RS232 (9DSub) or 8pin DSub and you can/have to download the software form Canon's web page.
2answers
2answers
Incoming audio fails from remote location
hi
as u mentioned, (firewall), when u do this the audio packets get blocked, u need to open the audio ports or best is to go for a dedicated bandwith only menat for the VC so there is no security issue & u can use the VC much comfortably
Hope this helps..
Problems using HDMI
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
