Just the handle on side of tub plastic
SOURCE: Hotpoint side by side no dispensor door handle loose
Removing the door gasket would probably reveal screws to separate both shells of the door - warning: door gaskets are expensive and may be hard to find on a fridge that old, so be gentle with it.
JOAT
SOURCE: Our sink is a double sink,black enamel --- one
Just a note here that this phenom does happen just like toilet tanks just crackin while you are sitting in the living room watching TV. There is no explanation for it.
While I personally would not expect any manufacturer of anything to pony up 2 years after their warrenty expired, to each his own. I do however believe it would be good public relations if they gave you a replacement.
I understand your anger and frustration but I ask to to remember that getting a Ford Mustang that is a total lemon from the factory does not equate to all Ford Mustangs being lemons or that everything Ford makes is a lemon.
Godd luck and I hope they come through for you.
SOURCE: need parts for a 30 year old jacuzzi toilet
Depending on what the innards look like, you can spend $15 at a home center like Home Depot for a toilet replacement parts kit. They're easy to install (about 30 minutes) and fix most common toilet issues.
If this won't work you might need to contact a plumbing supply company in your area. You'd be surprised what they have in inventory....
SOURCE: My jacuzzi bathtub plastics pipes underneath are
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
