Measuring Tools & Sensors Logo
Fadel Shaaban Posted on Sep 29, 2017
My La Crosse WS-9046U showing only figure 8 throughout the screen. How do I fix
5 Related Answers
Anonymous
  • Posted on Sep 22, 2008
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Anonymous
  • Posted on Nov 23, 2008
SOURCE: I need a user guide for a La Crosse WS-9211 Weather Station clock
Solved it! La Crosse let you download manuals from their website.
Anonymous
  • Posted on Apr 04, 2009
SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Jul 24, 2009
SOURCE: Display is fading
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
Anonymous
  • 583 Answers
  • Posted on Feb 20, 2010
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Need manual for la crosse weather station model: WS - 1612 - 11
https://www.manualslib.com/manual/91064/La-Crosse-Technology-Ws-1612.html
1helpful
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
4helpful
We have an atomic clock with calendar and temptature on it. We changed the battery and it is now on Eastern time zone, not Pacific time zone. How do we set it? It is La Crosse Technology Radio Model #...
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
