Question about Patton Dryers
Need rotor shaft plastic washers for Patton CQ-18 HV fan
SOURCE:
SOURCE: to repair 18" lakewood stand fan mod.#HV-18-p
unplug the fan!
1 remove the six screws that hold the front grille on.
2 use an allen wrench to loosen the screw that secures the fan blade assembly to the motor shaft. (screw is between the blades and the motor and it is on tight, make sure that you do not bend the fan blades, this would cause balance problems)
3 remove blade
4 you will now have access to the screws that hold the motor cover in place.
5. when reassembling make sure that the strain relief (or knot in the cord on some models) is inside the motor cover, and that wires are not being pinched.
6. Good luck
Posted on Jun 04, 2008
  • 2976 Answers
SOURCE: are replacements for the plastic control knob
Knobs for almost anything electric or electronic are available at Allied Electronics. Here's the link.
http://www.alliedelec.com/
Posted on Oct 01, 2009
SOURCE: How do you clean Patton Floor fan?
The grill is in two halves with the back half attached to the motor. The front with the round patton insignia removes easily by applying leverage with a screwdriver. There are eight spots (at least on mine) where it clips. Be sure to remove any disposable plastic fastener holding the two halves together. Its pretty easy.
Posted on Jun 02, 2010
mcdevito75
  • 1970 Answers
SOURCE: are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Posted on Jul 28, 2010
  • 8 Answers
SOURCE: Patton 1887 fan blades wont turn
I've had an 1887 since the 90s -- great fan. I have to say that FixinFax (Solution 1 above) probably didn't try to take his unit apart. My blade has stopped rotating several times over the years and I always got it going again by myself. I'm no whiz, just your average amateur handyman. In fact I am fixing the motherbleeper right now because in a week where the heat is 100 degrees it chose to slow down and stop.
Eventually it sucks enough dust into the axle housing so you have to take the motor mechanism apart and clean it. It's not terribly complicated, but you have to note how the electrical and mechanical parts go back together before disassembling. It's a little tricky to get all the housing parts to line up level again, you may have to try a couple times till the blade rotates freely. Wipe out all the dust and gunk buildup. Lubricate the axle with oil, or I just spray with WD-40. Then reassemble.
The only thing I have had to replace is the on-off knob, since it's plastic and it split. Just get a universal knob from your local hardware store.
Posted on Aug 25, 2010
Hello i have a hv-180 18" when i plug it in
Yes. These fans have thermal protection in the motor, as well. The thermal fuse or thermal breaker may be bad.
Mar 09, 2011 | Honeywell HV-180 18" Commercial Grade...
I have a hv- 18 model lake wood fan and the drive shaft gets sticky and the fan won start. tried light oil but it didn,t seem to help chuck ecsenger @yahoo.com
Clean out any and all dust in the fan as that is the start of the "stick" and then get some electric parts cleaner from a local supply store. Beyond cleaning solutions the problem may lie within the motor itself (brushes, stator, etc.)
Oct 29, 2010 | Dryers
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Need a source for a blade for a Patton U2-1887 fan
Try McMaster Carr -- page 640, Fans and Fan Blades.
http://www.mcmaster.com/#ventilation-fans/=8qgdv5
Aug 29, 2009 | Lakewood HV-18 Floor / Box Fan
I am looking for a fan control knob for this unit at our hospital
Radio Shack carries many types of control knobs. They may have one with the shaft configuration you need or get one with a set screw that you can tighten onto the shaft.
Aug 25, 2009 | Honeywell HV-180 18" Commercial Grade...
Aug 19, 2009 | Lakewood HV-18 Floor / Box Fan
Engine trouble
clean bushing and check alignment and lubrication..
Jun 22, 2009 | Lakewood HV 18-c Floor / Box Fan
Sep 12, 2006 | Patton Electric U2-20 Box Fan
Dryers Logo
168 people viewed this question
Top Patton Dryers Experts
Tom Chichester
james ayers
Are you a Patton Dryer Expert? Answer questions, earn points and help others
