I went to telekom store in wonderpark Pretoria to change our data package on land line. Its not done yet i tride to contact them whit out succes. I need a number to adress this problem. Thank you. Floirs Potgieter 081 323 5218
SOURCE: Not able to view incoming call details
check microsoft.com forums - there is a fix where you have to set the area code or something to the correct length
SOURCE: kenwood major mixer
Get in touch with the agents
Kenwood Home Appliances
1295 Clubhouse Street
Maraisburg, Gauteng
South Africa
011-474-0153
SOURCE: the fax console is recieving the land line number
The problem is not in the configuration, but the fax connection. The fax modem port must be connected to the fax jack - not the same jack you connect your phone to.
SOURCE: I keep getting error code 0xC004E002 and the
probably ur ram is faulty..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
dis also do happen when ur cd/dvd rom drive is down or the cd frm
where u r installing is corrupted..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation, it may b caused by the main/mother board or even the battery..
..contact ur system admin/vendor....
