Locking beaks together, making weird kissing sounds, looks like the male bird is feeding her but he don't have food in his mouth,
Hehehe.. maybe its time for some "little cockatiels".. PLEASE contact your local (or not so local) Ornithologist.
Welcome to Cockatiel com Your Complete Cockatiel Source
Learn the Basics of Cockatiel Care
Winged Wisdom Pet Bird Magazine Breeding Cockatiels pet parrots exotic...
Basics of Cockatiel Breeding
time between mating and egg laying
SOURCE: Clicking central locking
I have seen the driver door switch do this very thing. Replaced it and fixed the problem.
SOURCE: LG Microwave LMV1650st wont heat food
Hi eb6181,
If it's within warranty, I'd exercise that and get it fixed.
Usually, if it appears to run, but isn't heating, the magnetron has gone
bad. It's not a cheap part, and not really a DIY (do-it-yourself)
operation. If your warranty covers the part, that will help a lot.
Even if not within warranty, I'd have an authorized service center do
the job. They should have a list of authorized outlets with your
manual and other literature. They can also give you a quote as to how much it will cost - - only you can make that call.
I had a magnetron replaced once, it was spendy, but ~20 years ago, microwaves were a lot more expensive than they are now.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
SOURCE: Noisy central locking Nissan MIcra
Hi there, this is a very common fault, you need to replace the drivers door actuator to stop the noise, ive done loads of these. hope this helps.
SOURCE: Nissan Micra 04. The central locking is making a noise
Hi there, this is a very common fault, what ever side door the noise is coming from you need to replace the door actuator to cure the noise, Ive done loads of these, not sure how much it is though, hope this helps.
