SOURCE: motor pulley
bshu, first get yourself a bunch of rolled towells or something of that nature to place between the tub and rear cabinet. This way when you lean it back the pulley will stay centered with the hole. Remove the cap to the thrust bearing, it just pops off. You will see a lock ring sitting on washers. You can remove this with a flat blade screw drive and the cam will come off. Pull down on the pulley but be carefull to remember the order of the washers and bearings. If you are going to replace the thrust bearing kit, the part number is 12500036 series 12. This kit will come with a new pulley. After you have installed the new kit, getting the last retaining clip on can get frustrating. It is tight and you may need a third hand...hope this gets you going.
SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
SOURCE: metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
SOURCE: I have a Maytag wringer washer Model N2LS. When I
Might need some oil. I have a quart or 2 left over.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: have maytag E2L wringer washer. ser #111871A. need
I think this is the tool your looking for. Let me know if it is not the right tool.
