I have a Hotpoint wdd 960p washing machine witha an error code F01. water intake problems I believe the fault to be on the power module which I have removed. I cannot see any signs of damaged components. ie swollen or leaking capacitors, burnt componets or pcb. Any help to identify the problem please would be most welcome.
SOURCE: Burnt ic chip on Korg microKorg pcb.
Hi Mate, I have the exact same problem, casued by wrong adaptor being connected by accident, did you manage to find what the code is on the IC5 chip ?, I can see NSV, but there is another letter or number before it but cant make it out as that where its burnt.
SOURCE: Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
SOURCE: What does a fault F01 signify on a Hotpoint Ultima
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
