SOURCE: how can I reset the safety thermal cut out from my
the diagram on this page shows the safety thermal cut-off on top of the heating vessel on the right, inside the unit, remember to electrically isolate before opening.http://www.tanklesswaterheaters.com/tempra12.html
SOURCE: I am a homeowner and
The reset button is kicking out because the themostat is not....The reset is a safety switch so to speak. It is there to turn off the element incase the thermostat does not. I nrare situations the reset can go bad and kick at too low of a temperature, but usually not.To check out what is actually happening you will need to replace the t-sta and see what happens or sit there with an electric meter and monitor what happens in what order, very time consuming...
My recommendation would be to just change the t-stat and rest bot at once and you will be good again.
heatman101
