Question about La Crosse Measuring Tools & Sensors
La crosse TX7NU
The transmitter shows temp but main station isn't picking up reading
    Top Expert:
  • La Crosse Master
  • 54,195 Answers
  • Remove all batteries
  • Install known-good batteries in transmitter. Wait for it to initialize and begin sending data
  • Install batteries in "main station". You should see temperature displayed. If not, the transmitter may be ng
Posted on Sep 24, 2017
  • richie46 Sep 24, 2017
    Main station also has a reset button. Nail it also.
SOURCE:
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Posted on Sep 22, 2008
SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Posted on Apr 04, 2009
  • 474 Answers
SOURCE: not picking up outside unit
you have to have the station and the sencers close to each other when you put in the bats and then give them about ten mins
Posted on Nov 08, 2009
Testimonial: "thanks - working now! :-)"
  • 514 Answers
SOURCE: need instructions for model #2316 La Cross
per the manual at http://www.lacrossetechnology.com/2316/manual.pdf on page 2 section 5 the unit sets its self to the world time radio signal from boulder colorodo on its own after it get the security code from the sensor pack.
Posted on Nov 18, 2010
  • 157 Answers
SOURCE: THE CLOCK IS ON A
Hello. Not certain what you are trying to do with the clock, so I have attached the link to the company's list of manuals. Simply select the make and model you have, and the information should help you. Failing that, the company does have a contact page, and I am certain they will be able to assist. Good luck.
If this has helped, please rate it a four thumbs up. Thank You.
http://lacrossetechnology.com/support/manuals.php
Posted on Mar 29, 2011
Testimonial: "spot on, many thanks"
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
Outdoor Temperature Transmitter not working
Sometimes, you have to remove all the batteries in the transmitter and receiver and wait a few minutes before the next step.
Then you replace transmitter batteries first and within 30 seconds, get the batteries installed in the receiver. This allows the receiver to link up with your transmitter. Both units need to be reset this way. You'll see the temperature and any other information the transmitter provides come up in a few minutes. This works with my La Crosse weather station. Using the reset buttons without removing power will not work. My nieghbour has a weather station from another manufacturer and this is also the only way that his will link up.
Oct 03, 2016 | Radio Communications
Manual La crosse TX37-IT
station is not giving me an outside reading
Mar 31, 2013 | La Crosse Measuring Tools & Sensors
My temp only reads LL.L and will not show the temp
Please look here:
http://search.aol.com/aol/search?&s_qt=sb&q=lacrosse+wt+8005u+w+owner%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 23, 2013 | La Crosse Technology WT 8005U W Atomic...
Cannot get the outside temp to respond on a WS9047U-IT
Bring the outdoor sensor indoors. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the outdoor sensor. Put the batteries back in the main unit. DO NOT PRESS ANY BUTTONS. Wait 10 minutes or until the outdoor temperature shows. Once the temperature shows you may use the buttons to set the clock, etc. If it does not show after 10 minutes, then try again.
Jan 07, 2011 | La Crosse Measuring Tools & Sensors
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the...
The new batteries could be defective or installed incorrectly. Remove all batteries and start over again. Be sure to let the transmitter initialize and begin sending data before you install the batteries in the receiver. If you can't receive a signal, the transmitter may have failed.
I have an Oregon Scientific receiver that is within line of sight of the transmitter and receives nothing......
May 17, 2017 | La Crosse Technology WS9245UBKITCBP...
Not picking up outside unit
Nov 08, 2009 | Sport & Outdoor - Others
Measuring Tools & Sensors Logo
713 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
