Network ID Benjidrew
SOURCE: Need password
WHat type of router are you using? The default username/password for linksys routers is: "admin"/"admin" and for Netgear is "Netgear"/"Netgear"
SOURCE: dish network
Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
SOURCE: 2 Network ID on one PC
What operating system are you using? If it's Windows XP, go to Control Panel, Networking, right-click on the first network adapter, Properties, then select TCP/IP, Properties and enter the appropriate network settings for the first network. Repeat for the second network adapter and second network.
SOURCE: I need to add a password to my wireless network
Do you want to secure the wireless network ?
For that you will need to access the router set up.
You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
If your network is not secured yet then you will need to make it secured and enable password protection on it.
Click Here to know more about how to make it secured
SOURCE: Setting up wireless printer Brother
Log in to the management console, if the settings have changed you will have to reset the router to the most basic settings then start it up again, do this by turning to the back of the router, most routers have a pin sized hole in the back, stick a pin down that hole and hold it steadily pushed down for 5 to 10 seconds, release and wait 5 to 10 seconds and try again, hope this helps..
