SOURCE: wiring schematics
Kohler has an entire technical library on their website. Go to Kohler.com and you will find it. good luck
SOURCE: 1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
I think you still have a fuel issue like your float level is to low,I hope this helps you
SOURCE: wiring diagram for ignition switch farmall 140 tractor
FOUND YOU A WEB SITE FOR WIRING DIAGRAM
CARTER & GRUENEWALD CO. INC.
IF THAT DOSN'T WORK LOOK UNDER FARMALL 140 WIRING DIAGRAMS AND THE SITE WILL BE LISTED THIS SITE WON'T LET ME COPY AND PASTE TO YOU
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
