SOURCE: Charge battery, ride bike for about 30 to 45
5-6 years old is actually pretty old for a motorcycle battery. I would try replacing the battery first, then if you still have the problem, it is probably the voltage regulator. Honda is known for having very reliable bikes, with crappy voltage regulators in them. Yamaha's are the same there as well. I had the same problem with my Yamaha VMAX and by changing the regulator, I have not had another problem with it. You can find them on Ebay for around 50 bucks.
SOURCE: what does it mean if my blood pressure cuff says
Hi
a rise pressure most a time is normal,it rises and goes down to normal. but i ill ask u to check it again.it just a signal. and if it presit pls see a physicain for medication
SOURCE: Timex Women's T5K188 Digital Ironman Pulse
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
SOURCE: 1990 regal starts, runs for
hi, please check you oil level, ( on level ground). when the car is running place an old rag in front of you and take off the oil filler cap (be careful not to get near the fan, fan belt) if no oil comes out of the filler hole possible fault: oil pick-up pipe (in sump partial block), / oil filter in sump ( blocked), oil pump worn, oil relief valve (returning oil back into the sump), spring weak / broken. the (E C U) ENGINE CONTROL UNIT has many sensors that can stop the engine: but try cleaning the (EGR) ENGINE GAS RECIRCLING VALVE, this valve recycles gas back in to the engine, ( must be CLEANED with BRAKE FLUID) this is a VERY DIRTY job, as this gets block with carbon (EXHAUST PARTICULES). the E C U will detect all of these sensors: the (ECT), TOP OF ENGINE engine coolant temperature sensor rough tick over, (HO2), EXHAUST DOWN PIPE, heated oxygen sensor checks mixture of fuel, can adjust air / fuel, it tries to keep car going / may flood engine. (M A F) mass air flow, adjusts fuel / air retio this sensor can so much fuel to the engine it may flood it. flooded engine mean WET spark plugs. i would put it on dianostic machine to check these out before paying for extra sensors. gerry
SOURCE: my electronic blood pressure/pulse monitor a few
I am no expert. I would think that if the old/original battery is no longer working, a new battery would restore the monitor to its original usefulness. I think it is important, in any event, to take the monitor with you to your doctor's office when you go to see him and to check your BP with your monitor when the doctor uses his "professional" monitor to see that yours is reading the same as the doctor's instrument.
