Question about Sharp Refrigerators
How to remove refregerator sharp door - Sharp Refrigerators
Dometic refregerator 2652, the inside refer. light and the check light on the front blink when i open the refrigerator door. then stops a bout 20 sec. after closing the door
Sounds like a possible loose connection somewhere that is shaking when the door is opened. Check the main plug/power connection to the refrigerator for corrosion or just looseness. The inside light is controlled by a door switch so you may have a connection problem there also.
Jul 11, 2015 | Dometic RM2652 Refrigerator
Door latch sharp 1870
The service manuals you need are here and here.
This is often a broken door open lever or door open button.
You should be able to remove the controller assembly (see video here) and see the parts you need to check.
If not, you will need to remove the oven from the wall.
You can order Sharp parts from Encompass here.
Apr 15, 2013 | Sharp R-1870 Convection/Microwave Oven
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
May 22, 2012 | Samsung RFG297HDRS 29.0 CuFt French Door...
Samsung side by side refregerator door left open for some time, the door warning chime does not come on
Check the switch just inside the door. If it's not chiming, it may not be switching the fan either.
May 03, 2012 | Samsung RSH1NEPE 554L SIDE BY SIDE...
LIGHTS WILL NOT COME ON WHEN DOOR IS OPENED.THE BULB IS OK AS IT HAS BEEN TESTED. refregerator works fine otherwise.
Your door switch is faulty.Normally the door swtich is a limit switch and its action is press to OFF, when the door is closed.Otherwise when the switch is released when the door is opened then the lights must come on. Use a good tool to take the switch out, you can use some goos quality switch/electric contact cleaners or even WD40 can be used. The switch must be pressed hard a number of times while you spray into the contact.If there is no result you will need to remove and take the swittch to find the same mounting type- normally On switch.Hope you get thei right. Good day
Aug 12, 2010 | Refrigerators
GE refregerator
this is a drain issue..check to see if you have a plastic drain trap going into back of refrig . its located about middle of rear of box. this is where your water drains out of and down to drain pan. this gets filled with food particles and such and stops up flow of water..remove by twisting and pulling out slightly..clean out and re=install...if you do not have this..go and remove freezer back wall..you will need to open drain and clean out trough under evaporator..use hot water and continue until water flows down into the pan..
Jul 11, 2009 | GE Refrigerators
FREEZER IS FORMING ICE IN VERY BOTTOM AND CAUSING DOOR TO STICK
first of all, defrost the freezer. after that swich off your refregerator for about 8hrs and place the thermostart point on 3...............now try it. i'm sure that your problem will be solved
May 15, 2009 | Viking Professional VCBB363 Bottom Freezer...
Amana SZD27MPW refrigerator water reservoir replacement
The watedr reservoir ha a crack. what do I need to do to repair. Do I need to replace it? Please let me know. GE Refregerator Models 20-27
Mar 25, 2009 | Refrigerators
Refregerator
if your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Jun 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
49 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
