It still smells like algee anmusty. Maureen P's not sure the of age
SOURCE: SMELL IN SIDE THE CAR FROM AC
There's no cabin air filter on your vehicle. What happens is dust, lint or so-on gets trapped in the evaporator core for the a/c and starts to stink over time. Ask your local parts store for a de-oderizor spray for your a/c.
SOURCE: 07 Honda Civic air conditioner has a musty smell.
You need to make sure that the evaporator housing drain is clear. There will be a small tube or opening that usually drains out under the engine compartment near the passenger side. Run the A/C with the car raised safely, and look underneath, you should see it dripping, if not, you'll have to find where it is supposed to be dripping and clean it out with something like a pipe cleaner. Even if you see it dripping, clean it out. Then you have to buy a can of aerosol A/C disinfectant, this should be available at any good auto parts store. Turn the A/C on high and spray the disinfectant into the intake vent of the system. The location of the intake may depend how you have the A/C set. "Fresh" pulls from the outside, usually the valence right in front of the window, "recirculation" pulls from inside the car under the center of the dash. I would do both.
SOURCE: Windshield washer not working properly
If you have used ANYTHING beside windshield solvent in you reservor, you may have created WAXING from soap in the bottom of washer tank, which clogs pump,lines, and nozzel....take the tank out and wash it..disconnect washer hoses at nozzel and clear with compressed air along with the nozzel...if you use solvent only you may have a worn washer pump or restriction...check those and good luck.....
SOURCE: the heater has a musty smell,I suspect i need to
It sounds to me if you are having a "musty smell" then you might have a problem with your condensation drain line for you a/c system or a small leak on your heater core. If it is plugged then water will collect in the vent system causing a musty smell from the water not draining and if there is a small leak on the heater core then coolant can collect in the vent system. I would run the a/c on a warm day and look for water draining from the vehicle around where the dash is located to check the drain line. As far as your air cabin filter most are located behind the glove box. You usually need to remove the glove box to get to the filter.
SOURCE: Just purchased 2000 lincoln ls v6 and half way
I would take it straight back to the dealer and demand they fix it or give you full refund!
