Did you try to reset the electronics to factory defaults? If still no results you can always disconnect the wires going to the "runaway" burner after killing power and insulating the loose wires.
May need a controller board for device.
Sears Online In Store Shopping Appliances Clothing More
SOURCE: Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
SOURCE: Frigidaire ES400 oven controls
Contacts are fused. Get a new one, cut the power and replace it.
SOURCE: kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
SOURCE: GE Profile Electric Stove, no heat, looks like it needs a reset
how do i reset my general electric range?
