To fix google search has stopped , try the following:
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
FIXED ! Well almost... This problem is happening with the 'old' Android devices; Software if changing every day and most of the updates are barely tested on all devices and Android versions. The spyware, malaware, adware, are then becoming day after day more aggresive and sophisticated. So, the clean solution if format/clean/reinstall Original software, no updates.
Another helpful hint is clean all software cache, saved data, for each application , one by one, and then...
install Avast antivirus free and block behaviours, "APP LOCKING" option, at least of "Play Store" and "Downloads".
You won't see anymore the annoying message, and device will work like a charm.
Thank you, Bye. FIXED !
SOURCE: Pendo pad 7 displays 'Unfortunately, Launcher 3 has stopped when accessing Google Play.
I don't know this answer but a little research on the net provided me with this web page which has a number of methods to resolve this issue.
Give it a go.
http://androidtipguys.com/forum/steps-fix-error-message-unfortunately-launcher-has-stopped-android-tablet-181.html
SOURCE: It says "unfortunately google.app s has stop" & after I push ok botton it message pops up again.
It looks like the Google Play Services (if you have a device that require Google Play Services) needs a reboot or you need to clean cache. If you are using google apps in a device that have no Google Play Services, then the apps will crash.
Also, clean the cache, go to settings, storage, and tap at cache data,this will clean the apps cache just in case there is a corrupt log.
Make sure you go to settings, go into WiFi see what WiFi is open or if your connection is connected than just go to your web and put google home page and you should be all set from there.
To fix google search has stopped , what to do is the following:
