SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
SOURCE: Dehumidifier Brand haier HD456E does not pull
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
SOURCE: Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: Unit runs but will not
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There can be many reasons why a dehumidifier will
not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong
with their dehumidifier
heatman101
SOURCE: just purchased a Danby dehumidifier
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
